Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :(
Page 2 of 3 <123>
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Yup, thats exactly what needs to happen !
Got back from the shop earlier and they cant get the bolt out either (An hour £££ wasted). So i’ve driven it home again and shoved it on the drive.
Ive got it booked in for the 4th of Jan, they said around £150 will sort it inc fitting of the new bolts and 2x new cv boots ive provided.
As i’ve got some time off work....I am thinking of just continuing myself now if it needs cutting, it meeds cutting. As-long as dont mess up thr knuckle in anyway....ive got a reciprocating saw that I wonder would get in the gaps as a hacksaw
would taken bloody forever like you suggest.
I can then undo it from the diff...remove the abs sensor & handbrake mechanism (again).
Take the whole flippin thing to a shop and get it removed.
......Trouble is for the sake of £150, hardly seems worthet.Might aswell let someone else suffer for 1/2 a day & its done then.
What do you think ?
Post #577017 22nd Dec 2020 7:49pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
For £150, I'll let them have the hassle Thumbs Up
Post #577023 22nd Dec 2020 9:05pm
mazza7282
lol I thought as much, its one of those “just because you can, doesnt mean you should”
The work includes the following:-
- Cut out the bolt between the knuckle
- Unbolt 1/2 shaft from diff
- Undo lower bolt (thankfully I was able to loosen this, so this bush can stay in toe. I got new top & bottom bolts
- Unplug ABS sensor, handbrake cable (I guess that means un-doing the brake drum that only recently put back together with those buttons from another brake shoe pin kit
- Somehow separate the shaft from the hub on the bench
- Add on my universal CV stretch boots
- Press in the new bush on the top of the knuckle
- Re-assemble (ill also make sure they adjust the shoe so its 6 clicks of the handbrake
Suppose its a no brainer, probably get them to do some welding on the subframe (yet more bloody rust) as ive noticed 2 holes.
Post #577035 22nd Dec 2020 11:03pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
https://www.ebay.co.uk/itm/10T-Hydraulic-P...SwvEFfcvI~
you also need 5 std wheel nuts and someone with a lathe to turn the outer diameter of the threaded section of each nut down down a bit so that it fits inside the slots in the puller's flange.
the wheel centring spigot on the drive flange is proud of the face of the drive flange and this means the puller's flange cant get up close to the drive flange resulting in insufficient thread of the wheel studs protruding the backside of the puller. the modified wheel nuts fit inside the puller's flange to address this.
Post #577045 23rd Dec 2020 12:57am
dexion7
forgot to mention that if its tight enough that you need a tool to get it apart you will also probly need one to put it back together!
ask your lathe friend to weld a spare big hub nut onto a suitable sized tube then turn the threaded part down so that its thin enough to fit down past the splines till the threads engage .
I've not made one of these and didn't need one because even though my splines were a very tight fit, sufficient thread was proud of the hole to get a nut on and tighten to pull the cv shaft fully home. however, I have heard of others who did not have sufficient thread and so I was prepared for the problem!
Post #577046 23rd Dec 2020 1:09am
mazza7282
Im not continuing with it anymore mate Big Cry
For the sake of £150, they can faff around with it themselves. It was because I couldnt the shaft separated from the hub
myself with my puller, is what caused me to start undoing the knuckle nuts (and snapping one of them). To aid in the loosening situation.
I was going to buy the land rover hub/modified but for the sake of all the additional tools id be buying.
On this occasion, it’ll get done my the garage.
Post #577053 23rd Dec 2020 10:01am
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Just to close my promise of pictures of the hub puller a friend and I made...
Sorry its taken a while. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #577835 31st Dec 2020 1:16am
mazza7282
Looks good - very manly lol Thumbs Up Current Fleet
FF L322 2.9TD6 SE
BMW e46 330ci Msport
Skoda Superb TDI Mk2, stage 1
Audi A3 8P 2.0 T 4x4, stage 2
Yamaha R6 13S
Triumph Thruxton R
Sold, but not forgotten
WJ Jeep Grand Cherokee V8
Post #577844 31st Dec 2020 9:34am
mazza7282
We’ll the knuckle assembly & shaft is out, but not separated (still !)
As their pullers wouldnt do it either.....As I already knew would be highly likely, the assembly would need to be walked up the road to a machine shop they use.
But as this was at 18:00 last night, it wascobviously shut
So I decided as the top bush has now been pressed in, to just reassemble it. As its in a position for
me to remove it again at a later date !
Those pins that hold the handbrake will eventually collapse due to rust on the disc splash sheild so when the weather improves ill then be able to tackle it all again, shove a new splash shield on it, new cv boots and anything it needs for that side.
For now its driveable, safe and the handbrake works
What I will say to anyone tackling this - Make sure you have the correct puller specific for this hub!
Without that, youll have a tough old time of it like me, as essentially ive spent £150 trying to get this hub seperated (me & the garage)/new top bush/new nuts & bolts for both. + the price of the parts. As im right back where I started, just with a new bush, nuts & bolts Big Cry Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #578562 5th Jan 2021 7:39pm
bigbo
I have been asked for some dimensions so hope this helps
Its made of 10mm mild steel, the bolt is M16 x 70mm with matching nut welded under the top plate.
MG TF 2003
Post #579189 10th Jan 2021 3:54pm
mazza7282
Bloomin marvelous
Thanks a lot Thumbs Up Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #579190 10th Jan 2021 4:13pm
So would have been far easier and cheaper to have bought the correct tool in the first place then sir? 👍
Post #579227 10th Jan 2021 8:46pm
mazza7282
well duuuh !!!! Smile Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #579268 11th Jan 2021 8:21am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I wish I had that a year ago when I replaced all four shafts with new reluctor rings , a pig of a job which I did with a large heavy duty tube and a sledge hammer now I can see a driveshaft boot needing replaced . Do you know if someone has been making this version of puller or is down to taking these measurements and giving it to an engineering shop. I think I could do the reverse refitting tool.
Post #579314 11th Jan 2021 3:30pm
mazza7282
I believe bigbo and a few others have been making their own pullers with assistance from freinds/engineering shops Thumbs Up I’m very greatful for this and my hopefully my mate is also making me up something similar too. Maybe ill tackle the rear again in the summer, or I will wait until those brake shoe pins rust through Rolling with laughter
I removed my front shaft with only a few knocks the other day which is good. I just know that something else will go wrong and I will be needing the puller again. The shaft is now at a garage having new CV boots fitted as I have no way of separating the joint from shaft myself Current Fleet
FF L322 2.9TD6 SE
Yamaha R6 13S
Triumph Thruxton R
Post #579370 11th Jan 2021 9:21pm
Page 2 of 3 <123>
