![]() | Home > Technical (L322) > L322 8HP 4.4TDV8 Gearbox Failure |
| GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561
Sorry to hear about your trouble. Not sure about the model numbering. I thought they all had the 8HP70.
| OO__OO Member Since: 15 May 2014 Location: Manchester Posts: 18
No towbar or evidence of one. Sold by Hatfields Liverpool, Land Rover main agents. Last 2 services were by them but no mention of gearbox. Last service at 96k. |
| GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2777
A different gearbox part number was introduced starting with VIN BA347155 but I can't believe that an 8HP45 was ever fitted. Microcat describes the boxes as 8HP70 from the outset which I expect to be true.
Only engine code is for EGR temp sensor which will not clear. Trans came up with P0741 Torque converter clutch solenoid - circuit performance or stuck off.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
The EGR fault code is probably this. Very common. I have it and it never clears. Instantly comes back. Will be getting it changed out at Rovertune in Reading soon
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
You could Google ... Tameside Transmissions.... It might be worth a phone call.
Just a thought on this OO__OO, you say oil change, but given your symptoms a power flush may be better.
LR's "sealed for life" means "sealed for life of any LR warranty that expire at 10years".
My mistake! The gearbox is an 8HP70 !!! I read the sticker with a mirror & my eyesight is not always so good. I checked again & it is embossed on the side of the casing 8HP70 |
Might need an auto tranny specialist.... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Trans is now fixed. Bought a second hand one with torque converter for £650+vat. Reputedly only done 32k miles.
| telly-addict Member Since: 22 Mar 2019 Location: Morayshire Posts: 140
Nice glad you got it sorted |
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Glad you found a relatively cheap fix , makes that a very cheap 4.4 |
OO-00, great result |
