![]() | Home > Technical (L405) > Possible DPF issues.. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
Back to independent to read codes. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3556 ![]() ![]() ![]() |
agree with Dr Rob
If you've only just bought it then I'd reject it Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1090 ![]() ![]() ![]() |
It’s a V6, perhaps an oil dilution issue? It’s a known problem |
Sounds like an ideal candidate to return it to where you bought it and walk away! |
jackcramerr Member Since: 13 Oct 2019 Location: London Posts: 220 ![]() |
Do you do short journeys?
One post and.....gone! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35827 ![]() ![]() |
might be still recovering from to much sherry on xmas day... ... - .- -.
numagoo Member Since: 25 Dec 2020 Location: Manchester Posts: 5 ![]() ![]() ![]() |
Wow give a guy a chance... Just driven 270 miles with a full DPF warning and car in restricted power mode (had no choice) had to get to where i was going. Seems to me like the car isn't doing its passive regeneration ! |
I do quite allot of motorway driving and backwards and forwards between Manchester and Devon.. No option to return the car unfortunately. |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3259 ![]() ![]() ![]() |
Right, I will give you the benefit of my experience to date (2011 TDV8). Any of these may be relevant or not.
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
Great post Dolphinboy, very interesting! Having a reference point for those values is super useful, ta! |
Sorry, please accept my apologies ![]() I recommended T&S Norman in Somerset to Dolphinboy who found the thermostat fault. The thermostat issue has added to the body of knowledge on here ![]() Take it there if you can maybe...? High pressure smoke test is a must. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
Dolphinboy many thanks for your detailed post.. i will be on with your suggestions!
