Home > Maintenance & Mods (L322) > Oil in the spark plug well
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Hi all
Decided that I'd do a service on the range being a 2003 4.4 v8, oil changed no issue, air and pollen filte changed no issue however doing the spark plugs, all 8 spark plugs would appear too all have oil all over them as you can see in the picture below. I know this ain't a good thing. Is this a case of changing the rocker and a spark plug seals or this something a bit more heavy then that.
Cheers all
Post #578244 3rd Jan 2021 3:44pm
Gsxr1250dave
Just replace your cam cover seals pretty standard issue on these engines and you should be good.
Post #578247 3rd Jan 2021 4:01pm
Bean19844
That an easy job to do is it?
Post #578248 3rd Jan 2021 4:03pm
Gsxr1250dave
https://www.fullfatrr.com/forum/topic16756...er+gaskets
Post #578262 3rd Jan 2021 5:13pm
Bean19844
Cheers dave.
Flipping wish I had the gaskets already as doing tee spark plugs I was pretty much 3/4 the way there with it.
Sounds easy enough tho so best order one and get it done same day I do the alternator I guess
Post #578270 3rd Jan 2021 5:39pm
Gsxr1250dave
Yeah order some up island 4x4 are good you need left and right side the kits usually come with outer and inner gaskets.
Some kits on the bay come with everything you need including new oil seals for the cam cover bolts.
Oh and some sealant for the bit at the back on the engine and remove the heavy cover 1st loads more room if you do
Post #578289 3rd Jan 2021 7:52pm
Bean19844
Already done mate. Ordered it all from island 4x4 as I need the alternator O ring as well. Looked it up and it seems easy enough to change.
One thing I did think of was the oil that was in spark plug well would have fallen into the cylinder. This will just burn off and throw out some blue smoke for a while won't it. No serious damage to worry about right
Post #578298 3rd Jan 2021 8:54pm
ChrisRRV
United Kingdom 2004 Range Rover Vogue 4.4 V8 Tonga Green
Have the exact same thing myself
Will be getting new gaskets after the alternator is done
Post #578521 5th Jan 2021 3:41pm
Bean19844
Don't forget the bolt/nut rubber seals as well mate. I made the mistake order the gaskets but forgot the bolt and nut rubber seals so held me up a day
Post #578523 5th Jan 2021 3:44pm
ChrisRRV
These?
https://www.island-4x4.co.uk/seal-bush-cov...27168.html
Post #578525 5th Jan 2021 3:58pm
Bean19844
Think that's the ones mate. I ordered mine from land rover as seals, gaskets I always go genuine. These two in the circle mate
Post #578529 5th Jan 2021 4:06pm
ChrisRRV
cheers
Post #578541 5th Jan 2021 5:10pm
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
May I suggest you had bead blasted and powder coated the covers while you are at it? It's well worth it. And since you changed the spark plugs, funds permitting, I'd also change the ignition coils...
Post #578549 5th Jan 2021 5:57pm
Bean19844
Vs322
Can I ask why you'd suggest going down that route for the cam covers please?
Cosmetically mines pretty rough but it's 17 years old and gets used as a proper work horse so the body work won't ever win any competitions so never really bothered with the engine bay tbh
Post #578552 5th Jan 2021 6:20pm
vs322
Mainly cosmetic reasons. One could also argue that the gasket channels would provide better sealing if treated. I had mine done for a modest sum, can't remember exactly so I'm confident it won't break the bank. Just make sure not to powder coat the inside.
Post #578554 5th Jan 2021 6:45pm
