Home > In Car Electronics (L322) > Do all late L322s have TV?
Bluespanner
United Kingdom 2012 Range Rover Vogue SE TDV8 Baltic Blue
As subject, do all late L322 have TV or was it an option? I’ve managed to play DVDs in mine but can’t see any soft key that says TV... Manual refers to it but I have a feeling I may not have it on my 2012 vse
Any thoughts?
Cheers
Roland
Post #578315 3rd Jan 2021 10:39pm
mjdronfield
It’s listed under the standard features, so yours should def have it.
A bit of info from the manual....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #578322 3rd Jan 2021 11:18pm
Bluespanner
I can’t seem to find it, my soft key only has DVD, no TV/DVD to toggle between.
Post #578407 4th Jan 2021 4:11pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
It's possible that your TV tuner may be faulty or has been bypassed to keep the circuit. What happens when you press the physical Audio/Video button 2011 TDV8 Vogue SE
Post #578409 4th Jan 2021 4:28pm
Bluespanner
Post #578410 4th Jan 2021 4:31pm
Bluespanner
It takes me there, from what I can work out I should be able to cycle between tv and dvd
Post #578411 4th Jan 2021 4:32pm
dennij
TV option should be displayed there. If you have the IID Tool check to see if the TV option is showing in the configuration. If not the easiest thing to do is check that you have the TV module installed
Have a look at this post to get an idea of it's location.
https://www.fullfatrr.com/forum/post382826.html 2011 TDV8 Vogue SE
Post #578413 4th Jan 2021 4:48pm
Bluespanner
Thanks, that’s great. I’ll have a look after work and report back 👍
Post #578421 4th Jan 2021 5:18pm
It should have it as Mark says, but tbh, it is pretty in effective and I never used line as it didn’t retain signal when moving (even on the dual view) There is nothing that can't be fixed with a hammer😜😜
Post #578440 4th Jan 2021 8:01pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
I quite enjoy my TV screen when I'm driven. Had it on all the way back from Cornwall last summer, was perfect. But naturally all depends on the signal strength, I was impressed with how it handed over between transmitters.
Post #579145 10th Jan 2021 10:36am
