![]() | Home > My Range Rover > Back with another Supercharged |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 ![]() ![]() ![]() |
Congrats and well done. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
northernmonkeyjones - is that to complement your hammer?? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
It’s just a different shaped hammer. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3332 ![]() ![]() ![]() |
We’re just over 150 miles in so far.
Yep the front bearing is a total |
Pressing it in and out of the hub doesn’t worry me too much, it’s the splitting the shaft from the hub bit that’s got me worried.
Let’s just put it like this, Un be known to me my local garage tried to split the hub off on my 12my, to change an arm bush, don’t know why.... but in the end when they put it back together they neglected to put the hub nut back on.. |
these guys make everything seem easy!! general advise is get a new assembly with bearings
Interesting video here showing bits of getting the fan shroud off the 4.4 TDV8 so it looks like my next job is in the pipeline now. |
Time for an update |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Glad it's nearly sorted and running good... yep, they look good together... |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I like that angle in the car. Perfect for a nice snooze whilst my wife is driving |
David, the diaphragms are dead easy to change and cost less than £20... Not starting (flooding in old-fashioned terms) is a common issue when the diaphragms dry out/harden and fail... |
Thanks Craig. I’ve tried before to refurbish a couple of reducers on the P38’s and they never maintained a pressure properly afterwards. These are 10 years old now so thought I’d swap them but am thinking I should probably have tried the diaphragms on these as apparently they’re much easier to do then the older ones.
