![]() | Home > Technical (L322) > 2010-2012 MY Heater blower motor change -HELP! |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381 ![]() ![]() ![]() |
FSR is located at bottom of dash on drivers side if dash is in place you need to remove the trim panel below steering column 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
how does the trim panel below the steering column come off ?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4344 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic57903.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
The WM says 4 screws and a clip when I read it iirc.... "Remove the 4 screws. Remove the clip." Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 177 ![]() ![]() ![]() |
There is a torx at the top left and top right. They are under the black plastic filler trim below the digi dash pod |
Sadly no joy. I checked for power at fuse 21 and all good. I also gave that fuse a clean up.
Plugged in today and had 4 permanent faults in the HEVAC module. 2 for temperature sensors and one connection issue (can't remember the last one)
Alinton Member Since: 05 Aug 2019 Location: Kilkenny Posts: 56 ![]() ![]() ![]() |
I've looked through threads but can't find a definitive answer to this.
Sorry just seen this. That black curved plastic cover unclips at the bottom and pivots at the top. You will need to push the cables back a bit to get more space. It is tight getting it off and tighter getting it back!! |
With the very restricted space I can't make that cover budge. |
I think I put a flat bladed screwdriver under the bottom and levered it up |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1240 ![]() ![]() ![]() |
