![]() | Home > Maintenance & Mods (L322) > TD6 Heater Issue |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
If I remember correctly, when the coolant temperature overheats the ac condenser fan starts to increase the airflow over the radiator and thus cool the coolant down.
| mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425
I pulled in to the drive the other night after work and my other half thought there was a jet flying over the house = it was the twin air con fans going full chat ! Think I need to try and get access to the radiator and feel if there is a temperatre difference between the top and bottom and see if the rad needs a flush . likewise I am aware of the plastic fan BMW water pumps for coolant circulation ! |
One thing less then. |
| stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 136
Just thinking out loud ...
stuart_2006 read your write up of the Renault thermostat mod and noticed that your thermostat is next to the engine outlet and not the inlet to the radiator , is that correct ? I also purchased the Renault mod and a new genuine top heater hose so think I will fit it but next to the engine outlet this time. Thanks for your input suspect it could be the answer as currently thermostat too far from the engine outlet |
Yep, mine is next to the engine outlet.
Fitted this morning and all topped up with coolant and bled using the 3 bleed screws . Will give it a try tomorrow. I did test the thermostat in the hose before I fitted it to prove it operates correctly . |
Many thanks for your input stuart_2006 , the issue was that the thermostat was too far from the engine. All fine now with the needle at the 12 'o' clock position whilst giving it some beans and all the heaters blowing cold |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
Can I suggest getting a cheap infrared temperature gun. Just point the red dot in any inaccessible part of the engine that you can't reach. You could see if a thermostat is stuck closed or open on either side. Used mine to find a sticky brake caliper. |
