![]() | Home > Technical (L322) > Heater fan woes again |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Condensation = water leak somewhere. Check front floor carpets, check rear boot well and side wells. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
It's possible the main fan has siezed up completely.
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159 ![]() ![]() ![]() |
Well I can confirm the fan spins nice and free, so thats envouraging ! Looks like I'll be changing that FSR regardless, nothing to loose, not going to get time today though..... Brrrr |
Just been through everything and its bone dry. Being a 2012 model I'd like to think a lot of those common issues had been dealt with, still alwasy worth a check ! I didn't check the sunroof drains now I think of it, not sure were they drain to ?? Maybe the air-con is past its best ? Tricky finding out in this weather lol |
Well after an intense hour of swearing I've changed the FSR and the fan works again..... If that is the problem and not just coincidence again.... there must be a better solution ?!?! 2 FSR's in 2 years ? Like a service item !
