Home > Technical (L322) > Heating issues
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Heating issues
Hi all
So ive noticed this morning there appears tii be a slight issue with my heating unit on a 2003 v8. I've noticed the passenger side works as it should however the driver side just blows hot air all the time (bit like my ex 😂)
Anyone on here happen too have any ideas. I've had a look through on tee search but can't find anything similiar
Cheers all
Post #581588 29th Jan 2021 10:11am
Gsxr1250dave
I had exactly the same. Common problem this one you need to change this its buried on the right had side as you look at the engine.
https://www.ebay.co.uk/itm/WATER-HEATER-CO...890.l49292
Post #581593 29th Jan 2021 10:38am
Bean19844
Oh joy. How hard are they too change
Post #581596 29th Jan 2021 10:56am
Bean19844
Part ordered so let's see how hard this is to change and if it does the job for me.
Thinking about it now, I did notice the driver side vents always seemed slightly warmer then the passenger side when set to the coldest setting even without the air con
Post #581715 30th Jan 2021 9:33am
kds2
England 2008 Range Rover Vogue TDV8 Stornoway Grey
Three jubilee clips one multi plug and wiggle it out the rubber bush mounts, long arms and lowered suspension helps as well.
Post #581830 30th Jan 2021 8:28pm
Bean19844
Sounds easy enough. Am I right in thinking it's on the passenger side of the engine bay
Post #581836 30th Jan 2021 9:41pm
kds2
Thats the one.
Post #581849 30th Jan 2021 11:35pm
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
But isn't this about interior balance? 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #582924 9th Feb 2021 9:13am
Gsxr1250dave
Yes interior balance, the unit has a valve for each side, left and right.
Post #582956 9th Feb 2021 1:40pm
Archieatkins
2007 Range Rover Vogue TDV8 Java Black
did this solve the problem? I have the same issue
Post #583474 12th Feb 2021 8:06pm
Bean19844
Yep sorted mine. Took all of 30 mins too change. Just invest in a 6mm spanner for cracking the jubilee clips off before unscrewing them
Post #583477 12th Feb 2021 8:48pm
Archieatkins
Ok I have just found what I need to replace but how did you do it? I can barely see it yet alone remove it and replace. Is there a guide somewhere?
Post #583976 16th Feb 2021 9:54am
Bean19844
What engine you got
Post #583978 16th Feb 2021 10:36am
Archieatkins
3.6 tdv8 - managed to take a photo of what I am looking at
Post #583979 16th Feb 2021 10:38am
