![]() | Home > Maintenance & Mods (L322) > Silicone replacements TDV8 4.4 |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1343 ![]() ![]() ![]() |
70mm. I bought a 500mm length off Amazon for £10.91. |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Many thanks,
I think I did them just 2mm shorter to get them on because the silicone is stiffer than the originals. Make sure you use plenty of silicone lube or they will fight you. |
Thanks for advice |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
got to do my oil cooler gaskets so will change these when i do it thanks for the info 2012 Vogue 4.4 TDV8 - Current
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
You have to buy it in a 1 metre length and then cut to size (I used the large jubilee clip as a guide. Unfortunately you end up with quite a lot left over which just sits on the shelf taking up space. |
I brought these https://www.ebay.co.uk/itm/Silicone-Hump-H...2749.l2648
