Home > Technical (L322) > Fault code B12A6-11 - Aux heater water pump and B1D32-00
cattona
Hi folks,
my aux heater on my 2011 TDV8 4.4 did work a number of weeks ago. I then paired with a newly bought remote and it hasn't worked afterwards - I think. Also, one day I was assuming it was exhaust gases from the aux heater coming up the left side of my bonnet but it may have been a sign of something gone? As it happens, car was in having a front suspension air bag replaced yesterday and the fault codes re the heater are as follows
B12A6-11 Auxiliary heater water pump
B1D32-00 Multiple flame interruption during heating cycle
Is B12A6-11 telling us the pump is gone and needs replaced? Anyone on here done that? Is it time consuming and would anyone have a number for that part maybe? Also, would a repaired pump solve the "multiple flame interruptions"? Or am I in luck and these are two different faults?
Thanks
A 2011 L322 Vogue SE 4.4 TDV8
Post #582671 7th Feb 2021 12:12pm
cattona
T hose replaced
I also now remember that sometime at the end of last year I had the T hose at the radiator replaced, where it splits water off to the aux heater. Dunno if that helps.
Post #582687 7th Feb 2021 1:44pm
Garnerj
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Did you ever resolve the issue with you fbh?
Post #654552 24th Jan 2023 9:33am
cattona
Yeah. No one offered any help or advice so I bought a used one and replaced the entire unit. 2011 L322 Vogue SE 4.4 TDV8
Post #654553 24th Jan 2023 9:47am
