![]() | Home > Maintenance & Mods (L322) > Heated and cooled seat filter location |
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3883
Their is a full section in the WM dedicated to seats, full of info.
| Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 352
Thanks Mate I’m on site working so upto my kneck in it thanks for the info I will check it out , appreciate you taking the time to reply |
| JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 299
I don’t have it to hand, but if you do a quick search there is a whole thread about taking these apart and replacing the filter - apparently it’s possible without taking the seat out.
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
There are two, one under the base & one hidden in the seat back.
Thanks for that info I’ll give it a go 2012 Range Rover Westminster 4.4 TDV8
front or rear of the base 2012 Range Rover Westminster 4.4 TDV8 2006 Discovery 3 HSE 260k miles and still going strong with a new owner |
Front.
| lostinespace Member Since: 19 Nov 2020 Location: Herts Posts: 59
I took mine out today to clean. Sadly the driver's seat fan isn't moving at all, and passenger only heats the back. £500 for both heaters. 2009 TDV8 3.6 |
