![]() | Home > Technical (L405) > Air suspension L405 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
If the front struts are original then oil is likely to have leaked from the shocks into the air-springs which prevents lowering to access height. Going into extended height while trying to lower to access height is a typical indicator of the fault.
Watty Member Since: 03 Oct 2013 Location: Kirkintilloch Posts: 56 ![]() ![]() ![]() |
Problem now sorted it was the exhaust valve at the compressor which was blocked, same problem as on the L322 a small hole drilled through the valve solved the problem 07 Vogue SE Java Black 3.6 TDV8
