![]() | Home > Maintenance & Mods (L322) > Jobs jobs jobs jobs jobs - Side steps gone soft |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7965 ![]() ![]() ![]() |
If you are going to brace it all up, there needs to be enough decent steel to weld to. On my TD6, I left it too late and they were shot.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
I just removed and binned a set on my mates 2007, a guy at the local car wash stepped on them to wash the roof and the whole thing collapsed, it was amasing how rotten it was, absolutely unrepairable... Removed them along with the front mud flaps and filled the two holes left in the front wing with some rubber grommets... Looked alright and cheap fix, he never used them for their intended purpose anyway...!! Pete
uzp315 Member Since: 19 Nov 2017 Posts: 428 ![]() |
Very useful info thank you both.
I managed to replace my side steps easy enough, on each one, 4 bolts up the sides and 2 on the frame towards the centre of the car.... for each side. There are a couple of bolts near the air tank, that you can’t actually remove, near the rear passenger side door, but the steps allow for that and can simply hook into place before you tighten the bolts again.
Pikey Member Since: 11 Nov 2020 Location: Cheltenham Posts: 39 ![]() ![]() |
I much prefer the look and the not-having-to-worry-about-them aspect of not having side steps, either fixed or deployable, and fromt what I've seen/read the deployable ones are even worse! My car originally had deployable sidesteps, they've long since been removed by a previous owner.
Hi Mjdronfield, thanks for the tips |
The bolts are relatively large mate, and bolts will have been in the holes even when side steps not fitted, so should be ok.
Good advice thanks. I have just booked a slot (long way off) with the local mechanics for this, but I will get under and have a look and if i can do it, I will.
Like this.....
Thanks. Looks no harder than a few minutes of adult-meccano. I do see some potential FFRR style gotchas with this though |
All the bolts will be very rusty, I tried easing all the bolts out just in case he wanted to put some on later but with plenty of easing fluid about 50% of them snapped, including the ones that don't have to come all the way out...
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 296 ![]() ![]() ![]() |
Thanks fellas, my new one doesn’t have side steps like my last one did and I was thinking whether to fit some.
Haylands - I think that is my concern too. So I booked into my local garage so they can deal with that headache.
That sounds a good find, post some pictures when it's done... |
