Home > Technical (L322) > Dreaded water in the tyre well |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
It could be your top boot seal failing.
25th Feb 2021 9:54am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Powerful UK has a YouTube video on clearing all 4 sunroof drains. 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
25th Feb 2021 11:28am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Exactly...
25th Feb 2021 2:26pm |
Calvey Member Since: 24 May 2020 Location: Bucks Posts: 5 |
Thanks DrRob. I had a look at the video and will have to check to see if the rear ones are blocked. sadly they don't show how to clear them, if they are. |
25th Feb 2021 9:52pm |
Furnitureman Member Since: 26 Jan 2021 Location: Leicestershire Posts: 332 |
a quick way to rule out the sunroof drains i have used over the years is to seal the sunroof with Vaseline, it will create a watertight seal, leaves no mess if wiped down well and allows the sun roof to be opened, i did this with my D3 and it stopped all the leaks related to the sunroof then when the weather was better i sorted the issue out, if after doing this you still get water ingress its not from the sunroof drains 2012 Range Rover Westminster 4.4 TDV8
26th Feb 2021 7:22am |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
Check for rear top hinges of top trunk doors. I had a water leak there, undo the top nuts and put some silicon under. RR HSE 4.4 2006 LPG |
26th Feb 2021 7:55am |
