![]() | Home > Technical (L405) > Sorry folks.... another FBH question |
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2724
They will not operate if temperature is too high . Been warmer recently down your way ? |
| Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 159
I did wonder but it was about 5 degrees yesterday first thing, that can't be too warm can it ?? |
Had a quick search and some mention 5 degrees is the cut off . |
Thanks, I tried a quick search myself but didn't find much. However if it's right then great and also its typical for me to try it when on the temperature cusp ! LOL |
| Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162
Just been through all this with mine.
| andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 367
The water pump failed on mine. If you've got access to a scanner plug it in. Mine was throwing up a fault code for the pump and was fixed under warranty. Current
Is this for the L322 ? I'm L405, however my "maybe not a problem at all" is it won't work when manually operated at the screen unit.
Ahh Sorry did not see the forum was L405.
