![]() | Home > Technical (L322) > M62 4.4 Coolant leak from cap |
| vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626
Now that I replaced the leaking water pump, I'm facing another issue. There's a very small coolant quantity slowly escaping from the expansion tank cap. It appears that some quantity is being let out at some point but not continuously.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Ask Robin at Duckworths to check but I thought the 140 cap was only for the first couple of years, IIRC yours should have the 200... I maybe wrong but worth a check... |
I'll definitely ask around to make sure I have the right cap fitted.
Thanks for the advice, much appreciated
| knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 836
what thermostat have you got in it
When I replaced the pump, I also replaced the thermostat. I used the 105 Deg., identical to the one removed. |
Do your Range Rover a big favour and fit one of these to yours, especially as you are in a hot place...
Hey Pete,
The original fit ones were hard to get hold of and very expensive when I fitted the kit...
Considering I paid 100+ euros for the standard one I just replaced, I'd say that cost isn't an issue. Even at that price, It isn't something you change very often. What really matters is having an improved system running within spec / manufacturer tolerances. |
i fitted a BMW one, cant remember what model it is off RR 2005 4.4 petrol
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Unless I can't read MicroCat correctly, that appears to be incorrect. It appears the 200kPa cap was fitted up to VIN 1A001049 and the 140kPa cap thereafter. PCD000070 (CAP) [ (V)1A001050 - ] PCD100200L (CAP) [ - (V)1A001049 ] Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
This interests me as I have moved from a 200kPa cap to 140kPa and changed the thermostat to an 88 deg C item. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
That is correct, sir! Also confirmed by my local LR dealership. |
