![]() | Home > Technical (L322) > Rear Discs |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3331 ![]() ![]() ![]() |
If you scroll down to the bottom of this page there's links to the workshop manual that you should be able to see.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6834 ![]() ![]() ![]() |
Or, if you have an IIdTool, it will do it for you |
Chris1573 Member Since: 30 Jan 2021 Location: Gloucestershire Posts: 162 ![]() ![]() ![]() |
Yes I downloaded the manual David. there is a link in there to an external JLR site that I can access. L322 2007 TDV8 3.6 |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 713 ![]() ![]() ![]() |
If you didn't change the EPB shoes, there's no need for the bedding process - which is more for the EPB shoes than the discs Paul,
So just tighten up the adjuster till they grip then back off a few clicks till they don't Pawl ? |
There is a specific quanity of clicks to back-off I think - probably to ensure the EPB applies the correct tension to the cable.
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 227 ![]() ![]() ![]() |
I replaced the disks and pads earlier this year but not the EPB pads, I did have to go through the palaver of the resetting of the pads for the handbrake. not difficult but does take a bit of time and I don't think doing it in the centre of a city or town works. I did mine on a rural road, it did take about 8 or so goes to get the brakes set, it did pass an MOT so I must have done something right. |
Sleepy Jen Member Since: 15 Feb 2021 Location: Basingstoke Posts: 32 ![]() ![]() ![]() |
There is a good how to video on You Tube from Powerful UK Ltd - Land Rover Discovery 3 & 4 bedding in rear handbrake shoes EPB. It is for a Disco 4, but the sytem and procedure is the same for L322's.
Thank you SJ... L322 2007 TDV8 3.6 |
