![]() | Home > Maintenance & Mods (L322) > IID switched extension lead |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4350 ![]() ![]() ![]() |
I recall a thread but cannot find it..spent ages so no moaning at me |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35865 ![]() ![]() |
i'm pretty it was Mike [baltic blue] that talked about these...i cant find the thread either!!.. ... - .- -.
It’s within a DPF one I think.....yes, Mike |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3881 ![]() ![]() ![]() |
Mines not got a switch, but Greg installed one the same way with a switch.
Any pictures so we can then maybe Wiki this idea? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I will take some snaps tomorrow and add to this thread, just opened a bottle of red |
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342 ![]() ![]() |
Easy to run it under the driver footwell trim. I broke one hinged OBD cover when it was hanging down and replaced it (I think it was more than £100!), so now I tuck it up out the way using blu-tac. It can't be seen.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3561 ![]() ![]() ![]() |
Yes was me and mine is pretty much the same as RR L322 above.
I routed mine round and its completely hidden. Cable tied it and the IID to a round bar on the front of the seat frame. Used a small cork pad to mark the ON side so I can do everything by touch.
I also cable tied the OBD door flap open via one of the vents in the kick panel |
Removed mine. It was not letting the iid read all the ecus for some reason. Back to manual insert mode |
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
Dr Rob - same here, removed mine. I suspect some of the cheaper extension leads do not connect to all the pins (also an issue with some scart extension leads). 2011MY 4.4TDV8 Autobiography Baltic Blue
Think you're right. It also stops me looking at too often |
