![]() | Home > Maintenance & Mods (L405) > Range Rover hood letters |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 409 ![]() ![]() ![]() |
Cut the template between each letter, and then put the template pieces over the existing letters on the bonnet then tape together - hey presto, perfect spacing. Current:
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 392 ![]() ![]() |
Thanks Z! I'll give it a try. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
evoques are smaller in size so it possible you have a set for that vehicle.. ... - .- -.
Hi Stan, The letters are the same size but the spacing is closer. Is that what you mean?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Are you sure the ones already on are correct?
Yes they appear to be correct. As I mentioned, the dealer installed the letters over the new 3M clear bra but installed them about 3/4" off center. I also checked with my wife's 2014 and they are also correct. Just have to cut template as D suggested and see if I can get them straight. Dealer said they would redo if I brought down but its a 3 hour drive. Mike |
Flyingfocrs Member Since: 18 Oct 2016 Location: On the croft with the horses Posts: 93 ![]() ![]() ![]() |
I’ve done this twice now with the same result, my rear template was embossed “sport”
Letters came out great! Cut template and then took measurements of all letters from the hood of my wife's bonnet. Thank you all again for your help!
