Home > In Car Electronics (L405) > L405 TouchPro Duo No Sound
Kot
1 month into ownership and my 2nd problem.
No sound from Radio/TV/Sat Nav/Telephone proximity etc etc
The volume button switches on and off but level is stuck on 12 and no sound.
There is an option to choose Stereo/Meridian/DTS/Dolby etc but it won't move from Stereo position.
I believe its at best a fuse, but tried them all using the fuse legend in the handbook, BUT not the Fuse Links (FL*) yet,
I dont have a drawing showing these beauties, (if anyone has would be grateful if you would share it) and of course they are not easy accessible in the loadspace fuse panel. Especially if you have fingers like a bunch of bananas lol
The other option of course its the amplifier.
Again as its an approved used in warranty, dont want to dive into this (unless its a simple fix like a fuse)
I have it booked at the dealer earliest appointment end of 1st week in May.
 2018 SE SDV8 4.4 Byron Blue
Post #591393 16th Apr 2021 10:06am
Andy B
There is some info about this issue on the RRS forum and it says there is mention of the issue in the software update 19B. It may be worth you checking what software version you are on (I think I am on 20C) and making sure it is up to date
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #591399 16th Apr 2021 11:02am
Chalky
I see your car is a 2018 model. Is it the facelift?
If it is, then your problem could well be one of the many software issues I had with my car, including no volume. The dealer only resolved the issues by fitting a brand new 2020 unit. Since then, up until the time I sold the car, everything worked perfectly. All LR cars from 1984
2021.5 Vogue SE D300 Carpathian Grey
2018 Vogue SE British Racing Green GONE
Post #591400 16th Apr 2021 11:02am
Kot
Andy B
I have the latest infotainment software S20C****.
But while on the subject of updates I also notice when you scroll down from Infotaiment update, to vehicle software update, it shows no software number and when you try to update it, it continues in a loop "checking for update" it never completes the cycle ? Is that normal?
I believe its unrelated to the sound issue though.
I have been watching RRS forum and others.
Chalky
Yes its facelift.
Post #591414 16th Apr 2021 12:49pm
Chalky
I think you might have to have the dealer activate SOTA All LR cars from 1984
Post #591415 16th Apr 2021 12:52pm
Kot
Thanks Chalky
I will certainly ask when it goes in, but thought as Infotainment update is working, that SOTA was therefore enabled?
I certainly updated the Infotainment software remotely on 18th March from 19C to 20C
Post #591417 16th Apr 2021 1:19pm
Chalky
Yes sounds as if it has been enabled so they should be able to sort it out for you. Have you checked audio settings under the settings tab? All LR cars from 1984
Post #591420 16th Apr 2021 1:26pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Here are the fuses: https://www.fullfatrr.com/forum/topic58513.html
The ones for multimedia are in the right part of the trunk/boot, 48, 50, 51, etc.
Have you tried disconnecting the battery for a minute?
Post #591422 16th Apr 2021 1:43pm
Kot
Chalky--Audio settings all checked it was the first thing I did.
adara--Thx but your fuse layout is different to mine as an example I dont have any fuses in F1 to F6.
But I like your diagram, it shows your Fuse links FL* I dont have that in my load space fuse panel, it would be handy they are not easy to id or access.
It will be a Fuse Link but need to remove upper access panel that incorporates the rear speaker to get access. Managed to squeeze the phone in to get this picture
Post #591454 16th Apr 2021 6:56pm
Kot
It was the Amp Module that was frozen, solution was to remove Fuselink to reset system and update module.
They also installed the new Infotainment Software S21A_21.106-676616 2018 SE SDV8 4.4 Byron Blue
Post #592527 27th Apr 2021 1:28pm
adara
Great! So, which FL was it?
Post #592529 27th Apr 2021 1:53pm
Kot
Adara
Razz FL16 its in Tech Bulletin LTB01226V2
Post #592558 27th Apr 2021 8:57pm
adara
Thank you! I wonder whether these fuses are available as parts. The micro fuses are already hard to find...
Post #592566 28th Apr 2021 7:36am
I had to get some micro fuses a while back and ended up at an auto electrics supplier. I think it’s a case of they aren’t sold at your general auto store and you have to get a bit creative when shopping for them.
Now I know where to go it’s not a problem.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #592567 28th Apr 2021 7:40am
adara
I found them on aliexpress, the name is Micro M Rectangle Fuse PEC
https://www.aliexpress.com/item/3302456442...web201603_
Post #592568 28th Apr 2021 7:45am
