![]() | Home > Technical (L322) > Ride height after air spring replacement |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
Check the height sensor hasn't flopped over the other way when fully jacked up... look at the one you haven't done yet... will give an idea of how it should be... |
Thanks Pete, I’ll check that out |
Also, have you driven it, they sometime wait until they move to set the ride height after being worked on... |
No, not moved it yet.
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
+1 Happened to me a few weeks ago |
Stuck my head underneath tonight & both look to be set up the same.
Looks like it's settled after a short drive to turn it around.
Glad it's found it's level head again... |
