Home > Maintenance & Mods (L322) > M62 v8 timing chain and guides replacement
Page 4 of 6 <123456>
Gsxr1250dave
Heads back on, timing done
Post #597190 11th Jun 2021 6:33pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
why did the heads need to be removed RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #597215 12th Jun 2021 2:38am
Gsxr1250dave
Found a small weep at 1 of the head gaskets
Post #597218 12th Jun 2021 7:16am
Danwilderspin
I bet that doubled the bill! Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #597266 12th Jun 2021 11:02pm
Gsxr1250dave
I'm getting mates rates not cost me a penny more in labour but I have paid for any additional parts required.
Post #597381 13th Jun 2021 9:51pm
Gsxr1250dave
It lives
Here is the 1st run up. We removed the plugs and fuel pressure relay and cranked it to get the oil pressure up refitted and turned the key.
Post #598609 24th Jun 2021 6:03pm
Danwilderspin
Sounds good still sounds like a little vanos rattle why didn’t you do that while you were there? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598630 24th Jun 2021 9:43pm
Gsxr1250dave
No vanos rattle all good on the test drive engine silent pulls like a train, iv been driving the wifes D3 the last few weeks so good to have my V8 back. Once the engine cover went on it purrs .
Got a few test drives to do gonna drop the oil and filter after 100 miles check the coolant level then finally get round to doing my headlining, A ,B and C pillar recover.
Thumbs Up Thumbs Up
Post #598634 24th Jun 2021 10:05pm
Danwilderspin
Must just be the sound -
What’s up with the pillars ? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #598647 24th Jun 2021 10:52pm
Gsxr1250dave
I had planned to redo my headlining at some point but it got put on hold its needs recovering so to make sure iv got a good colour match I aim to recover the A B and C pillars at the same time to freshen it all up inside
Post #598650 24th Jun 2021 11:09pm
knares
great news RR 2005 4.4 petrol
Post #598666 25th Jun 2021 2:47am
Gsxr1250dave
Main components changed
Post #598759 25th Jun 2021 4:57pm
Gsxr1250dave
Just to report all has been good with the rebuild no real issues except a slight vanos rattle on cold start up Whistle did some one ask why I didn't reseal them when it was apart.
The new crank shaft oil seal is also weeping so the plan is to replace that and pull the vanos off and replace the seals, only the drivers side has the rattle at the moment, my question is....do I honestly need the pressing tool iv read so much about or can I just replace the seals and refit ??.
Post #604773 25th Aug 2021 7:18pm
knares
Cant answer that, I bought the tool and the seals
I am keen to know what make timing tool you used RR 2005 4.4 petrol
Post #604810 26th Aug 2021 2:21am
Gsxr1250dave
The timing tool kit was an ebay special loads on there, I didn't buy the cheapest but turns out there all the same. The deep socket to remove the vanos solinoid didn't fit so needed machining until it did. None seem to come with the locking clamps that hold the cam locking tools in place but it didn't cause a problem.
Post #604829 26th Aug 2021 9:34am
