Home > Maintenance & Mods (L322) > M62 v8 timing chain and guides replacement
Page 5 of 6 <123456>
Gsxr1250dave
Found the answer to my own question, you don't always have to use the press tool after resealing the vanos. New O ring and Teflon seal can just be replaced. Will give this a try 1st just have to find a spare day.
Post #605287 31st Aug 2021 11:32pm
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
Gsxr1250dave wrote:
The timing tool kit was an ebay special loads on there, I didn't buy the cheapest but turns out there all the same. The deep socket to remove the vanos solinoid didn't fit so needed machining until it did. None seem to come with the locking clamps that hold the cam locking tools in place but it didn't cause a problem.
i thought i had answered this post but apparently I haven’t, thanks for your reply.
I used a cheap Chinese one too and the right hand bank is out of time according to the diagnostic tool RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #605294 1st Sep 2021 7:05am
Gsxr1250dave
Well it's been a while, 1 of the new hg failed after the rebuild so its all been stripped and done again. Just the hg this time, both of them for peace of mind with an uprated kit....heads skimmed and pressure tested all good a snapped bolt in the rear for the coolant cross over manifold was drill.out and Ali welded/plugged then redrilled and taped. I also resealed the vanos units while they were off as I didn't do it last time.
All put back together enuff for a start up today..........I can report......
IT LIVES...........IT LIVES..!!!!!!
Post #637097 17th Jul 2022 4:19pm
Gsxr1250dave
https://youtube.com/shorts/8T8APyEcKAE?feature=share
Post #637100 17th Jul 2022 4:34pm
Dolphinboy
Says video is set to Private Dave. Ned to login to see?
Post #637102 17th Jul 2022 4:54pm
Gsxr1250dave
Set to public, the pcv is not connected nor the air box, lpg etc so just rnuff for a start up
Post #637105 17th Jul 2022 5:01pm
Glad you got it sorted, hopefully that's it for a while..
Did you get round to doing the headlining yet..? Pete
-Click here for Thread-
Post #637135 17th Jul 2022 6:47pm
Gsxr1250dave
Fingers crossed its the last time messing with the engine. Not touched the headlining yet this has been at my mates place he has done all the work for me on his spare time.
He knows these engine in and out. Once the road test is completed and we're happy with it I will get back to those little jobs I had lined up.
Post #637137 17th Jul 2022 6:56pm
Thumbs Up Thumbs Up Pete
Post #637140 17th Jul 2022 7:03pm
Gsxr1250dave
Car drives like new after the rebuild but I'm chasing an old oil leak behind the oil filter housing connection plate.
I have of course replaced the O rings behind the plate but my question is the bit circled in red must just be an inspection plug and it must have an O ring. Before I take it out I just wanted to know if anything apart from oil is going to come out ?.
Any ideas ?
Post #645491 13th Oct 2022 12:13pm
johnboyairey
many years ago, i did my chain guides, at 140k drove it another 65k, till i sold the car, still purring.... but with a broken gearbox... i had no issues, apart from frostbite, as i had to do it outside during one of the beast from the east cold snaps. i changed the vanos seals, with a press tool, from usa. you dig out the seals, flick some new ones in, and then use the tool, with a pole, to crush or burr over the lips, to make then seal better. it went well.. had a minor oil leak, but sorted that out. also did a lot of other brittle parts at time, like rocker covers, valley pan cover, and water pump tubes. and also a cooler thermostat upgrade. these were superb engines in their day, but the high running temps made everything so brittle, and hard, so you got leaks galore, and overheating if not kept in check. even at over 200k, the internals looked splendid. i have a similar engine in one of my other cars, an 8 series bmw but not the vanos version. i followed the beisian systems procedure, and used all bmw parts. back in the day, the tool set was 400 quid, plus another 100 for the vanos tool. the job back then cost me about 1000 with tools, which i should have sold on, as i never used them again. i think still have the crank locking bar i made to stop the engine, so you can break the crankshaft jesus nut, with a huge pole. we didn't have battery windy guns then.
...happy memories... sort of..
Post #645500 13th Oct 2022 2:15pm
Gsxr1250dave
Yep this engine is pretty well sorted now and running like a dream just this historic oil leak which I'm sure is comming from the said counter sunk bolt, it's clearly in the oil way lookingvat the casting.......just wanted to see if anyone has pulled it before for reference before I do next week.
Post #645514 13th Oct 2022 5:30pm
knares
good luck getting that plug out
i wanted to take one out of the head, ended up welding a allen key to it
went to buy a new plug, $80 Germany only or USA one cent each $40 shipping or something
it didnt have an o ring, it was just a plug for a drilling in the oil way RR 2005 4.4 petrol
Post #645542 14th Oct 2022 2:38am
Gsxr1250dave
Thanks Knares, at least now I know its just a plug and nothing else. If I can't get it out I'm sure I can seal it up somehow from the outside.
Proberly explains why my guy nor me have either removed 1 before.
Post #645580 14th Oct 2022 1:57pm
johnboyairey
why not brake cleaner the front of the leak, and smear sealant over the face. -if it works, its a fix. no mechanical risk at all.
Post #645691 15th Oct 2022 12:01pm
