![]() | Home > Technical (L322) > Recommendations for a 4.4V8 Diesel Jump start pack please> |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2717 ![]() ![]() ![]() |
I used to disconnect mine , might be sensible getting a cut off switch fitted. |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213 ![]() ![]() ![]() |
thanks
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 781 ![]() ![]() |
How old is your battery? Have you checked it is the correct sized AGM? |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2622 ![]() ![]() |
Starter is probably on the way out. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7991 ![]() ![]() ![]() |
I was watching for the recommendation of a good jump start pack.... just in case....
One of the bigger NOCO ones - GB50 or GB70. |
CongoBoy Member Since: 11 Sep 2020 Location: Wiltshire Posts: 126 ![]() ![]() ![]() |
I've also been watching.
hbthepilot Member Since: 21 Mar 2021 Location: Bludenz Posts: 33 ![]() ![]() ![]() |
NOCO GB150 - does a very good job! |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 712 ![]() ![]() ![]() |
I've had a NOCO GB70 for a few months now and it's been fantastic.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
GB70 here, but I am installing a dual battery system from Traxide:
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3946 ![]() ![]() ![]() |
Ironically since I got my GB70 a few years ago I haven’t had a problem. I have helped a few other though - works a treat |
Thanks for the replies.
Ido t think the original was AGM. I will check the replacement |
You sure it’s the battery and not the starter motor?
