![]() | Home > Technical (L322) > Cracked LH intake manifold |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
If it is the Inlet Manifold, then it will cost c. £1600 to replace. Mine went on the Pax side and they are a known weak point - LR have had the part upgraded as the originals were unable to take the pressure of the 2 turbos and the flexing caused splits.
t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114 ![]() ![]() ![]() |
I would say it's most likely to be the manifold thats split as can also hear it with reving, I'll pressure test it and inspect Sunday. That's good news if they have a better quality manifold now do you happen to know the part number for the updated item or is it still LR034993 |
Chapeau! Velo Member Since: 22 Jul 2019 Location: Down South Posts: 115 ![]() ![]() ![]() |
I’ve literally just had mine done. LHS too (3.6 TDV8). Specialist says this is now a common problem owing to age and mileage. Mine was a £700 fix with a LR indi using genuine parts if that’s a helpful barometer. |
Pete, I think the number is the same but you could check with Duckworths.
RRover Member Since: 17 May 2021 Location: Sussex Posts: 278 ![]() ![]() |
Vindictive Added Tax is a killer these days...
Brilliant thank you |
Unfortunately the issue with plastic looks like it's most common on the lhs |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 941 ![]() ![]() |
Those look like replacement silicone connecting sleeves and possibly the jubilee clamp tightened a little too much placing extra strain on the plastic welded joint? |
Yes there the replacment hoses I changed the seam where the manifold has failed shouldn't be affected by the hoses and definitely not overtightend, to be honest I've noticed since getting our car there has always been a missing of oil round the lhd manifold area so been failing for a while by the looks of it |
Removal is quite a protracted affair apparently as the injector lines need to be removed hence the labour cost. |
I can definitely see a fair amount of labour.
