![]() | Home > Maintenance & Mods (L405) > Under sealing chassis? |
Bloke Member Since: 13 May 2019 Location: On the road to Oban Posts: 120 ![]() ![]() ![]() |
Not sure underseal would be the best approach. Have a look see here - https://www.dinitroldirect.com/affiliated-...directory/ |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Lanoguard is the new boy on the block... Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16342 ![]() ![]() ![]() |
Not the chassis BUT, there are plenty of rusty steel parts like, rear ARB unit, fuel tank guard, steel clips & clamps holding aluminium coolant pipes to the body for example... Brake pipes! Thats what ive found on mine... |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Craig, can you remove the shields easily enough? Nothing to support underneath once removed.
