Home > Technical (L405) > L405 Leaking O Ring replacement
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
Has anyone on here replaced the "O" ring at the back of the engine on a SDV8 ?
I've done the L322 TDV8 but the newer one looks a mare to access !!
Post #596207 2nd Jun 2021 1:32pm
archermav
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
https://www.fullfatrr.com/forum/topic35977...+leak+sdv8
try here mate. Recently had my oil cooler replaced. Was rather a good leak from it. Indy reckons it was a bit of a job to do.
Post #596216 2nd Jun 2021 4:59pm
Ragingrover
Thanks. Yes I've seen this when I did the job on my TDV8 but now I've got a SDV8 and although the problem is the same, so I beleive.... the access is quite different, thats my issue, a look this morning lead me to beleive it would need taking the windscreen wipers off !
Post #596219 2nd Jun 2021 5:06pm
Yes it's a bit more involved than a 322... Done many of them to date...
BIG tip! The large bolts holding the strut braces, undue them with a socket and bar ONLY... Never a windy gun as the steel bolts suffer from steel/aluminium corrosion... If the captive nuts spin then you can get to the bottom/underside of them with a socket Thumbs Up
Post #596244 3rd Jun 2021 12:08am
Ragingrover
Thanks for the reply :¬)
So this is a potential oil leak on these too ?? I've checked as best I can around the cooler and filter housing and its clean but also smells clean, so my next thought was the O ring.
Post #596254 3rd Jun 2021 7:55am
