Home > Technical (L322) > Rear Wheel Arch Liners
RR2B
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Baltic Blue
It might be a dumb question, but can the rear wheel arch liners be removed without first removing the wheel? Iโ€™m paranoid about working under a jacked up vehicle, axle stands or no axle stands! Thanks. 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #597139 11th Jun 2021 11:20am
Merchy
I have a 2006, and to do that I think I would have to be a magician. Whistle At the risk of sticking my oar in -
As for axle stands - the following will see you safely through a job, and ease your fears
Buy good quality units
Correct rating for weight - as described on here 6 tonne may seem big, but have a good large ground support area, and generally higher lift
Place stands under correct points, see some of the photos of posts on here where people have posted repair / work photos if you are unsure as to placement
Stick the wheel you remove under that side of the car, leave jack in place ( locked) with weight on axle stands
Ensure you are on a level surface and if the ground is not very hard, ie thin tarmac, use a hefty pieces of wood under the stand(s) / jack
I use two axle stands where one would be adequate, as an extra safety measure.
It goes without saying, NEVER work on a car when only on the jack
Always carry out correct procedure to stop the car suspension lowering during work, I always allow extra height for this so if it drop on the bags, it will still be safe underneath.
Apologise if this is 'Teaching granny to suck eggs' it's all about practice and confidence. You could practice with the TVR, it must be light as a feather Rolling with laughter
Post #597143 11th Jun 2021 12:13pm
RR2B
Thanks Merchy - thatโ€™s the exact same procedure I used to follow when working under the TVR, but I doubt if my 2 tonne jack and axle stands would be man enough for the RR. And if something did go wrong under the TVR I would at least have a fighting chance of survival! 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #597144 11th Jun 2021 12:23pm
Merchy
Maybe it's time to invest in some new shiny tools, just do it quietly so the boss doesn't see all the new gear Rolling with laughter
As I said, it's all about confidence in the gear and your skills. A while back we had to stand under a suspended marine diesel crankshaft, to carry out final inspections and cleaning prior to lowering the crankshaft into the bed plate, so we had to have confidence in the lifting gear, as the crank shaft we worked under weighed 145 tonnes.
Thought you might like the photo of a similar one, taken at an engine builders. As I said, lots of practice and confidence Thumbs Up
Post #597145 11th Jun 2021 12:48pm
Much safer to take the wheel off than leave it on, you stand more chance of getting injured with the vehicle supported just by the airbags, if one goes pop, the system decides to lower, you knock off a pipe, etc with your hands in and around the wheel I hate to think what injuries you would get but you would find out who your real friends are the next time you need the toilet...!!!
If you have an IID tool, empty the suspension of all air and see how low it goes...!!!
Jack it up, use decent stands, give it a good shove equivalent to you falling against the car and check it doesn't move.... Thumbs Up Pete
-Click here for Thread-
Post #597155 11th Jun 2021 2:04pm
RR2B
Sulzer? 2011MY 4.4TDV8 Autobiography Baltic Blue
TVR Griffith
Alfa Romeo Mito QV
Post #597158 11th Jun 2021 2:17pm
Merchy
Good advice Haylands, I usually drop mine to access level prior to any work, I have an I-carsoft LR reader, but the more I read, the more I think I will be better off biting the bullet and getting the Gap tool Thumbs Up
RR2B - Yes, sulzer / wartsila, the one we did was a sulzer RTA, now modified to become the Wartsila Flex camless engine, my pics are very dark and grainy, so not much good, but I am looking for the photos I took with the A frame being lowered and we were under it applying sealant to the top of the bed plate. It was a fingers crossed moment.
Post #597159 11th Jun 2021 2:19pm
Baltic Blue
Merchy,
All I can say is Wow !!!!!
Thanks for the picture.
145 tonnes is unthinkable. ๐Ÿ‘๐Ÿ‘
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #597162 11th Jun 2021 2:44pm
