![]() | Home > Technical (L322) > Home made gearbox flush 6HP26 automatic gearbox |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Deleted |
Deleted |
Deleted |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
That's one way of doing it.... |
Ingenius... |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2750 ![]() ![]() |
NEVER run the gearbox without oil. The gearboxes are filled with oil then the pump primed before the gearbox is fitted to a vehicle. Draining the oil for an oil change doesn't drain the pump. |
Deleted |
The first component to fail when inadequate oil is in the pump is the seal to the E clutch which shares the same shaft. Unless you're speaking from experience of having allowed the engine to run with nil oil intake even for a few seconds then IMO you shouldn't be advocating that no damage will be done by doing so. |
Deleted |
Deleted |
How big is that catch tank/receptacle/bucket thingy please, save me measuring the box beforehand..?
Deleted |
Deleted |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Brilliant idea and well explained. Just to check did you flush through with zf6 atf and I presume it's junk and thrown away when both flushes have been done?
