![]() | Home > Technical (L322) > L322 2004 HDC & LOW RANGE SWITCHES |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 626 ![]() ![]() ![]() |
I had the HDC and LR PCB re-attached on the gear selector trim a few months ago as all the retaining screws' threads had fallen apart.
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Opening up the centre console is not as bad as you may think, I followed the below excellent thread to change my ignition switch, so the video just about covers what you may need to do. If you can't get the bits there are some good condition used parts around, just a case of a good web search. A complete panel with switches is easy to source. Quite a simple swap.
Thank you for the encouragement, sir! Now, I could certainly combine taking apart of the...bridge telegraph with replacing the cubby box gas struts, perhaps killing two birds with one stone or...more likely doubling my job list in an instant. Boy I hate messing with interior trim and panels |
Got incredibly lucky this afternoon to spot this little b@stard in the chair's rail!!!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Sorted. I’m never keen on garages doing stuff on my car. They just don’t treat it as I would.
True! But I can't fault them as they didn't quite expect the retaining setup i had in place at the time. I should have removed the piece myself but quite frankly wanted to keep my social distancing. Chalk it up to COVID.
