![]() | Home > Technical (L322) > Suspension lowering when parked |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2947 ![]() ![]() ![]() |
I had a quick look last night and both arms are in the same place. I assume you mean the arm would be facing the opposite way? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Yes I had 22” Hawkes and one cracked. I had it repaired professionally but last week before departing for Dorset I noticed a bulge on another one. As the Toyo tyres were starting to crack I decided to fit a set of 20” that I had bought for the winter instead of forking out for a new set of 22” tyres. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
RichTD6 Member Since: 02 Mar 2011 Location: Lincolnshire Posts: 85 ![]() ![]() ![]() |
Hi Andy, yeah, was hoping it was something as simple as one arm flipped over and facing the wrong way but if you’ve already checked then that can’t be it unfortunately.
On further examination it lowers when I open the tailgate. Otherwise it will stay at ride height for 2 or 3 hrs before lowering. Weird 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Don't know if it's the case on the L322s, but my Disco 4 does that to aid loading the boot. Might be worth trawling the the RR encyclopedia otherwise known as the handbook. |
Mine doesn’t do this normally. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
