Home > Technical (L322) > TDV8 Power steering Fluid leak
tomo_
Poland
Check the radiator and alloy pipes. Mine was spilling oil like hell all over left side of the car from the bumper up to the rear of engine frame mount. Luckily it was short drive , so I didn kill the PAS pump by dry run Bow down
Mainly pipes of radiator around plastic clips that hold them to the main radiator frame.
Post #508158 10th Mar 2019 11:05am
L322 Newbie
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
Hi Tomo
Thanks -car is back in the garage tho week lets hope they can get it sorted, will update later when they get access to the front Steve
2007 L322 RR Autobiography Black
1999 X100 Jaguar XKR Black
2008 Smart 451
Post #508160 10th Mar 2019 11:29am
Fatboy Slim
United Kingdom 2008 Range Rover Vogue TDV8 Zermatt Silver
Apologies for the thread resurrection....
Mine has also succumbed to the leaky power steering cooler.. it appears that the part has been superceded so hopefully the newer type will be an improvement. I've bypassed it for now to keep it running, seems semi pointless in our climate anyway.
Post #664129 14th May 2023 9:16pm
tomo_
Poland
Usually there is oxidization of the pipe under the bracket
Post #664142 15th May 2023 7:07am
KitTheRam
United Kingdom 2009 Range Rover Vogue TDV8 Santorini Black
Hello, found this tread as I have a PS fluid leak in the same place, turns out I have a hairline crack in the alloy pipe circled below for the oil cooler after inspection - dried the area and then turned the wheel to see what was what - slight drip.
Sounds like it’s a total pain in the bum to change. I’m I right that there is an upgrade to this part or have read a previous post wrongly?
Is there any solution to fixing a hairline crack in this thin pipe? E.g. https://bondrite.co.uk/product/aluminium-e...ehicles%2C
And using a previous post’s picture…
 2009 pre-facelift 3.6 TDV8.
Post #688821 23rd Mar 2024 7:33pm
tomo_
Poland
I've tig welded it.
Post #688842 24th Mar 2024 8:41am
