![]() | Home > Technical (L322) > Passenger deployable side step given up |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 786 ![]() ![]() |
99% certain it’ll be the pivot points seizing up. They are difficult to lubricate in situ but easy to remove to work on them |
Privanthe Member Since: 18 Apr 2021 Location: Linlithgow Posts: 63 ![]() ![]() |
I’ve tried lubing and cleaning.
Managed to get my Indy to look at it today with an hours notice, but as I was getting into the car to go to them, the step has suddenly started working again.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
if you have tried to use the step with the engine running and it didnt work at that time , then its probably not the battery.. ... - .- -.
Makes sense. Bummer! |
Probably just your lubrication efforts finally soaking in a bit.
Thanks.
To avoid squashing dogs, small children and old peoples feet the motors are designed to stop/reverse if they feel any resistance so I expect that the resistance of a stiff pivot is enough to fool it |
