![]() | Home > Technical (L322) > can any one help rear subframe mounts |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8816 ![]() ![]() ![]() |
The only thing I can think is that I'm pretty sure that part is fixed to the monocoque, if the rest of the cover is fixed to the exhaust you may get NHV transmitted through to the cabin... There again, maybe not...lol.. Can't see why you can't try and see... |
oggy Member Since: 09 Sep 2020 Location: padstow cornwall Posts: 395 ![]() ![]() ![]() |
thanks haylands i have fixed the rear to the under side of tow bar frame tapped in 10mm hols and it needs picking up to the front it does miss the exhaust rear box completely . i have today pick up a hanging both sides from the 8mm bolts on that mount i have also put some rubber bushing in to take out a solid fix bit of movement see how we go if i have any probs i will take my bracket of the bolt wear the exhaust rubbers bolt on thanks oggy new vehicle purchase
