Home > Technical (L322) > Best Head Gasket Sealing Formula?
garyRR
One/both (3.6 TDV8) of my head gaskets have failed between combustion and the cooling channels. I have ruled out other potential causes such as EGRs and thermostat housing.
It's time to trade the car in and get another. What's the best head gasket sealer I can chuck in?
I read Steel Seal or K-Seal. Any recommendations? 2015 Range Rover Autobiography 4.4 SDV8
Post #601080 19th Jul 2021 9:36am
Sam
None of the aforementioned. None of them work. The combustion pressures are way too high for anything like that to have a hope of working.
Post #601088 19th Jul 2021 10:16am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
check out this post
https://www.fullfatrr.com/forum/topic54543.html 2011 TDV8 Vogue SE
Post #601090 19th Jul 2021 10:19am
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Might as well just pour a bag of sugar into the cooling system with that mate instead of k seal etc
Post #601091 19th Jul 2021 10:25am
garyRR
So how do I get rid of the car then?
Just trade it in? 2015 Range Rover Autobiography 4.4 SDV8
Post #601092 19th Jul 2021 10:28am
Bean19844
Depends on who you plan on selling it too. If you go down the wbac route then you'll prob be OK but other dealers may be able too chase you for a faulty sales of goods route
Post #601093 19th Jul 2021 10:41am
garyRR
Ok, I won't bother with any liquids - I'll try selling privately with a head gasket problem and if not, I'll be sending it to auction and cutting my losses. 2015 Range Rover Autobiography 4.4 SDV8
Post #601114 19th Jul 2021 2:46pm
Sam
Probably the best option. However, before you do, has it been confirmed as a head gasket? Might be worth shelling out £100 or so for a decent garage to perform a cylinder leakage test just to be sure. Please note there is a big difference between a compression test and a leakage test. A compression test is fine for a burnt valve or suchlike, but a leakage test is far better at detecting a head gasket leak, especially if it is only minor.
Compression test; Imagine trying to blow a crisp packet up with the other end torn open, you'll never do it.
Leakage test; Now imagine blowing a crisp packet up that only had a pin hole in it. You'll blow it up but it will eventually go down.
The reason I'm labouring the point is that if you have a leakage test and it fails, then at least you know for sure one of the heads will have to come off. However if it passes, you may find whatever coolant leak you have, it's not a head gasket and could end up being something relatively straightforward.
If you do decide to get it checked, make sure the garage knows the difference between the two tests, as a surprising amount don't.
Post #601117 19th Jul 2021 3:11pm
Slow progress
That seems sensible Sam, otherwise Gary you could be throwing away a lot of money.
How much is a head gasket repair vs. Uplift in the value of the vehicle at point of sale.
Post #601146 19th Jul 2021 5:15pm
garyRR
The quote was £5k for a head gasket repair.
The car has been no end of problems, from a dodgy dealer. It will be going. I will not be spending any more money on it.
Back to my question please. 2015 Range Rover Autobiography 4.4 SDV8
Post #601149 19th Jul 2021 5:21pm
dingg1
Whack 2 bottles of steel seal in it, see if it improves, trade it in...
Post #601152 19th Jul 2021 5:29pm
