Home > General > Who is running a "high mileage" 4.2 Supercharged
Wanderer83
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Rimini Red
Keen to hear from high mileage 4.2 S/C owners - looking at adverts these things seem to go on for ever. Any particularly expensive faults that crop up at they go past 150k? Thanks
Post #603221 8th Aug 2021 6:18pm
Rosco
Sandyt is your man Very Happy
Post #603227 8th Aug 2021 8:19pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine is on 230k. Gearbox has been refurbed before, pulleys and tensioners and viscous fan all replaced. Engine internals seem solid enough. Supercharger bearings need to be replaced and the isolator as the miles creep up.
To be honest the biggest thing to look out for is rear wheel arch and sill rust - that can be expensive to sort!
Post #603234 8th Aug 2021 9:51pm
Piet
Netherlands 2008 Range Rover Autobiography 4.2 SC V8 Lucerne Green
Hi
Mine has done 150600miles.
Running perfect and smooth , knock knock on wood. Bow down
Only normal maintenance except for the SC bearings.
Done that a few weeks ago.
Post #603291 9th Aug 2021 4:35pm
Wanderer83
Great to hear - thanks everyone
Post #603343 10th Aug 2021 6:57am
xjsracer44
United Kingdom 2007 Range Rover Vogue SE Supercharged Java Black
Mine is now on 170,000 miles & has been very reliable so far 🤞 as long as you keep on top of maintenance & rear arch bubbling. I can’t find anything to replace her, so will keep her as long as possible, I would say she’s probably good for 300,000 with proper preventative maintenance, so go for it Thumbs Up
Post #603354 10th Aug 2021 10:39am
conor
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
I've just bought with 162k miles.
Not even received yet... :eek. I have an intro post in the intro thread.
Post #605005 28th Aug 2021 12:16am
Sandyt
Just topping 220k (its been a light couple of years mileage wise) I have run it for 8 years bought it with 60k on the clock
All working as it should and I drive hard often long runs into Europe.
I change the oil and filter every 10 k and change the fluid in the gearbox and diffs every 30k its worked so far
I have changed all bullies and tensioners as well also front air bags shocks all round and all bushes were done at about 180k but that is more a personal thing with me.
I still use mine daily in fact of to
France again and will do upwards of 2k on the trip and not concerned about reliability.
Mine was also chipped and had the supercharger pullies replaced by previous owner . It is quick enough Thumbs Up
Post #605016 28th Aug 2021 9:25am
Sandyt
The only thing I would say is mine is high mileage but I have put the miles on it so know how it has been serviced although doubt if the others are driven any harder Thumbs Up
Post #605018 28th Aug 2021 9:31am
LandyGee
Interesting thread chaps!
Would you say that the supercharged is more reliable than the tdv8? I’ve heard that a number of times…
And the classic question.. around town and on small runs, what mpg are getting??
Many thanks!
Post #606180 11th Sep 2021 9:54am
Sandyt
Interestingly enough I never use the the onboard comp normally but reset no 2 before my run over to France last week and it showed 21.6 mpg over 1300 odd miles the other is on 15.6 and has never been reset by me so that will be over just on 160k miles To be fair I just fill it up with 98 and off I go.
Post #606181 11th Sep 2021 9:59am
Sandyt
No idea if they reset when the battery is disconnected if so no idea of the miles
Post #606183 11th Sep 2021 10:01am
LandyGee
Cheers Sandyt.
What would you say re reliability vs the tdv8?
Post #606185 11th Sep 2021 10:03am
Sandyt
No idea afraid dont like diesels can only report on ones I have owned I still have a classic and a p38 just run them till they break then get a new one but always end up fixing the others
Post #606186 11th Sep 2021 10:06am
Rosco
Landygee, throughout the years you hear a lot more about issues with the TDV8 (3.6), whether that is because there is more of them who knows, but it's down to preventative maintenance IMHO, SC do however seem to be more reliable,
Sunny East Ayrshire here also Thumbs Up
Post #606187 11th Sep 2021 10:09am
