![]() | Home > General > What Did You Do In Your Full Fat Today |
Bardley Member Since: 01 Jan 2025 Location: Hertfordshire Posts: 57 ![]() ![]() ![]() |
Checked the passenger side sill cover to see how the ACE pipes were looking: Pretty clean.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1874 ![]() ![]() ![]() |
Ian Bodsworth arrived today bang on time and treated our fullfat to a full transmission blood transfusion, so it should hopefully be good for another 60K miles, I had just done both diffs myself at the Weekend, so that’s all fluids changed on the car now |
NOTSHARP Member Since: 04 May 2025 Location: Aberdeenshire Posts: 63 ![]() ![]() ![]() |
I dropped her off at the Spa this morning.
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190 ![]() ![]() ![]() |
Paired new FBH remote ready for the winter to the new to me L405, paired first time. Loved the feature in my old L322 on those cold northern morning. Must saying loving the Autobiography luxury |
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 198 ![]() ![]() ![]() |
Took all the underbody shields off (metal and plastic ones) and gave it all a thorough jet wash. Used the snow foam gun to cover the underside and then hosed it all off. Amazing how much crud was stuck up behind the trim panels and how dirty the underside was in general. Once it is thoroughly dry I am going to give everything a coat of Lanoguard before it goes back together. It’s a filthy soaking wet job but pleased it all clean under there now and with the Lanoguard should be all good for winter.
landy95 Member Since: 04 Aug 2021 Location: West Midlands Posts: 86 ![]() ![]() ![]() |
I stripped the intake system down to clean out the lovely carbon oil chocolate brownie mixture. Very satisfying. Replaced the vacuum pipe on the air filter box the garage had missed when they serviced it prior to purchase.
Doonhamer Member Since: 07 Jul 2017 Location: Thatcham, Berkshire Posts: 214 ![]() ![]() ![]() |
Drove from Saint Valery sur Somme to L’Abbaie et Jardins de Valloires; an hour’s drive each way, stuck to the D roads and passed through some amazing little villages. Would like to have got the RR in front of the abbey for a suitably grand-looking pic but not possible - still looking for a suitable alternative before I return to the UK on Monday. Loving it out here, the roads are so quiet. L322 TDV8 4.4 - current
Andyyav Member Since: 13 Mar 2017 Location: Norfolk Posts: 235 ![]() ![]() ![]() |
Not today but recently, all oils and filters, ACE tank, coolant tank as it hadnt been changed when the previous owner had the oil cooler replaced, A/C panel and CarPlay upgrade and finally paint correction and ceramic coat
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 569 ![]() ![]() ![]() |
Finally bit the bullet last weekend and removed the sill finishers on both sides. Expected to see the inevitable rust with rot holes, BUT, nothing other than fairly mild surface rust! You could have knocked me over with a feather!
Vigilo Member Since: 27 Apr 2025 Location: Nottingham Posts: 10 ![]() ![]() ![]() |
Re-fitted a new TPMS module I bought a while back as the old one started playing up again.
latteLarry Member Since: 11 Jul 2025 Location: South Hampshire Posts: 9 ![]() ![]() ![]() |
Fitted a new front airbag strut, took about 4 hours in all, after making sure I had the correct size tools, then the active damping light came on |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 703 ![]() ![]() ![]() |
Hi,
