![]() | Home > Maintenance & Mods (L322) > L322 2010 rear seat |
RJPotts Member Since: 19 Aug 2021 Location: Durham Posts: 208 ![]() ![]() ![]() |
A thump backwards on the backrest? Sit in the seat, have a shuffle around & then try the latch again to see if it has returned to un-pressed?
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
Same here - fiddle around with a small screwdriver from behind to release the catch. There seems to be a metal rod that jumps out from a plastic actuator, you can access this by prising off the plastic cover. 2011MY 4.4TDV8 Autobiography Baltic Blue
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Thanks all will have a go a bit later and just found a good write up on here as well . Thanks and will report back. |
Seat repair complete and cost nothing .lol thanks for all your help. Indeed the rod had come out, so i put star clip over end and sorted. I |
