![]() | Home > Technical (L322) > Are my Starting problems simply down to my battery? |
TeeMyob Member Since: 22 Jun 2019 Location: Javea/Manchester/Abu Dhabi Posts: 213 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic60587.html
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Bloody hell….. other than checking all the connections, which must have been done…. There is only the alternator left, though I’m sure you will have checked it’s charging.
14.7 volts when engine running
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Given the fact that you've changed the battery and starter I'd be inclined to look at the ignition system. Could be something to do with the key not sending the correct info to maybe a dodgy earth strap.
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 ![]() ![]() ![]() |
I have had no starting issues since i cleaned and tightened up the electrical's. (still observing)
Thanks @ffrr14 I can’t see that diagram very well. May I ask where battery box 2 is please ? |
It is behind the battery. The one marked was loose for me, but I removed and cleaned all of that and the box next to it as well.
Thanks everyone, my car is off the road again.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4348 ![]() ![]() ![]() |
Get them to check, clean and test all the connections in the circuit from battery all the way to starter motor. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Dr Rob - beat me to it. Sounds very much like a connection issue than a component failure. |
Thanks for the replies.
