Home > Technical (L322) > MOST fibre optic connectors |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6672 |
You can't just buy the connector, as the "cable" is fibre ie glass, so unless you have a cable splicing tool, you can't attach a new connector - you'll need to buy a complete cable assembly I'm afraid! |
24th Mar 2011 10:46am |
Hi Alan, I was afraid of that, although they were able to "loop" the cable (joined both ends) to keep the system going (I think). So I have someone looking for a connector with two bits of cable still on it and see if I can repeat the trick. Otherwise I need a hand splicing tool as well (in Nigeria you can almost find everything) from Europe.
24th Mar 2011 12:20pm |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
Sorry Alan, thats not strictly speaking true, the problem is finding someone who will sell you just the black connector You can "take apart" each connector removing the two fibre optic cables - I have done this to extend the MOST circuit on my Wife's D3.
Eugene - Are you looking for a male or female black connector? - Should be male! Also, are the two fibre optic cables with their black end sections that locate into the connector still in place? If so I may be able to help Andy. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
24th Mar 2011 12:59pm |
Hi Andy, I agree that you can take the connector apart and use the little black "junction box" to extend the length, but I was sure you had to have the ends on the cable(s) to allow for them to line up inside it? I'm also pretty sure when I did this, each cable on either side of the box clicked into place (using the cable end plug) so it was lined up with the cable plugged into the other side of the box. I can't see how you can line them up if the cables have no plugs on the end of them, but I'm open to be corrected! :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
24th Mar 2011 1:31pm |
Hi Andy,
24th Mar 2011 4:01pm |
Hi Eugene,
24th Mar 2011 4:50pm |
This may help understand the MOST circuit but its from a D3/RRS
24th Mar 2011 5:03pm |
Hi Guys,
24th Mar 2011 5:35pm |
Yep that should be fine Unplug the MOST connector from the SDARS module and plug it into the Bluetooth module if the cable is long enough Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack. SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone. Gone: 2014 Discovery 4 HSE Luxury Firenze Red Gone: 2006MY Java Black TD6 Autobiography Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner, |
24th Mar 2011 6:34pm |
Hi Andy,
24th Mar 2011 6:42pm |
PM your address and I am sure we can sort something out 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
24th Mar 2011 6:46pm |
Just realized I never closed this out but Andy helped me getting a connector that made the whole system work fine again (once the new BT module from Wiggs was installed) !! MY 2010 5.0 SC Galway green and sand interior!!
18th Jul 2014 9:10am |
jonlewis Member Since: 06 Nov 2012 Location: UK Posts: 308 |
As an aside to this, the TMC unit only seems to have a single connector where everything else is two.... is that normal ? 2011 Stornaway Grey 5.0SC Autobiography |
18th Jul 2014 10:30am |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 605 |
It's actually plastic, cheaper and generally more robust - important for automotive certification procedures. Glass fibres can be seriously expensive and generally automotive stuff gets even more expensive. It's usually more difficult to certify a system for use in an automotive environment than a military. Certain electrical systems are not only not supposed to survive a 120V spike from a load-dump but also continue working through them! Hence why using POF would be preferable because once you've gone through the automotive certification it'll have at least tripled in cost. Besides - I know that FFRR's are big but I don't think you need the ~10km range of normal fibre optics... |
18th Jul 2014 7:38pm |
