Home > Technical (L322) > 09-12 Headlights??
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
09-12 Headlights??
Does anyone know what factory options there were in the UK?
I know the late 12 had black insert.
Did any have adaptive lighting?
Part numbers would be handy.
Also if AFS is an option, is a module required to upgrade?
Post #606609 16th Sep 2021 9:16pm
Mine has AFS and Cornering headlighs, I imagine a brace of ECU's to help them on their way but can't help with the technical side really...!!! Pete
-Click here for Thread-
Post #606676 17th Sep 2021 2:18pm
JNC
Would you mind sending me your VIN? Via PM?
Want to see what the part number comes up as.
What year is yours?
Post #606692 17th Sep 2021 6:11pm
GraemeS
Australia
The VIN won't identify part numbers, only build features.
Post #606701 17th Sep 2021 9:43pm
JNC
I was going to put the VIN into parts catalogue. Will show the part numbers applicable to that vehicle.
Post #606793 19th Sep 2021 12:50pm
GraemeS
Australia
I hadn't thought of trying to use the VIN that way but having just put mine's VIN into Microcat 2012 it still shows both headlight options, not just what's fitted to mine.
Post #606794 19th Sep 2021 1:01pm
GraemeS
Australia
The part numbers are shown in Microcat. The electrical diagrams show an AFS module some distance from the headlights as the wire lengths between the AFS module and the headlights are several metres. If wires exist in pins 5, 7, 13 and 14 of the headlight connectors then the wiring for the AFS module is installed.
The AFS module appears to be in the vicinity of the forward end of the centre console.
Post #606797 19th Sep 2021 1:22pm
A UK 12my would have only 2 options. With or without AFS, now on 12my (black internals), the non AFS headlamps had the cornering lamps deleted/painted black! So, if you find a black internal 12my headlamp with chrome cornering lamps then it's highly likely to be a Highline lamp... Check the wiring plug to confirm its a 16 pin ??? (I think that's the right number)
The 9-11.5my lamps with grey internals, all externally look the same so are harder to denote... The cornering lamps on NON-AFS lamps are chromed the same as the AFS lamps, just don't have the LED packs fitted... The larger amount of pins in the wiring plug would then denote its a highline light Thumbs Up
Hope that all helps sir... Thumbs Up
Post #606831 19th Sep 2021 8:52pm
