Home > Technical (L405) > Front Hydro Bush
fenair
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
Front Hydro Bush
Guys just had a 60 month service and the dealer has picked up on the "front Hydro Bushes " split, i do a google search on that description name on the inspection sheet but nothing comes back, any ideas as to the terminology ? is it the bush on the ACE arm?
2015 4.4SDV8 L405
TIA
Pat
Post #607080 22nd Sep 2021 6:30pm
knwatkins
Hi Pat, he's referring to one of the bushes on one of your front lower suspension arms.
A hydrobush is oil-filled as opposed to a traditional, solid rubber bush. This provides a more progressive response of the bush as the wheel deflects (ie. more deflection = more firmness in the bush).
ACE (active cornering enhancement) refers to the old active (hydraulic) anti-roll bar sytem from the Discovery 2. It's called Dynamic Response now, but many people still call it ACE. You will have this as you have the SDV8, the SDV6 does not. There are two bushes on the active anti-roll bar but these are solid rubber D-bushes which is the same as a normal, solid anti-roll bar.
Hope this helps. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #607089 22nd Sep 2021 9:04pm
fenair
Many thanks Kev That points me in the right direction, cheers.
Post #607099 23rd Sep 2021 6:28am
M3bobby
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Fuji White
Resurrecting and old thread so apologies.
I had a small pool of oil on my drive, directly under the front lower control arm bush. The oil is light weight and is spotted with black bits, not like engine oil. There is oil dripping from the bush and no signs of oil above it so I’m assuming the bush is a Hyro/hydra bush. I also now have a rattle felt through the steering over light and regular bumps such as a rumble strip. My question is, does the below image show a hydra bush as I suspect it is!
Post #723725 31st Aug 2025 11:22pm
M3bobby
Just to wrap this up, I changed the bush today, it had about a 1” split in it and boy does it drive better now.
Post #725283 28th Sep 2025 6:56pm
