Home > Maintenance & Mods (L405) > L405 inverter install
Likeomg
Hello All,
I have a 1500 watt pure sine wave inverter i use to charge RC cars / boats Lipo batteries,
Currently in the back of the defender but would like to wire it in for a upcoming trip to Germany,
Anybody done it? tips tricks?
Preferably would wire it into the rear, could run a cable direct from Battery but is there a better option?
Post #607257 24th Sep 2021 10:32pm
AJGalaxy2012
A much better alternative is to use a 12v charger for these batteries.
Chargers such as this one will be way more efficient than using an inverter https://wheelspinmodels.co.uk/i/294676/ BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #607264 25th Sep 2021 5:24am
If you're going to do it, then depending on the size of it, there may be an obvious location -
Post #607269 25th Sep 2021 8:21am
AJGalaxy2012
150 amp 12v feed also required….. BMW i3 Electric Car
Post #607280 25th Sep 2021 10:05am
Likeomg
Im charging big packs and lots of them so have quite a bit more powerful chargers than the above, one boat runs
14s2p usually for 3 mins run time. so 14s 10,000mah... I have one on 12s2p (16,000mah)
my charging setup is designed around a 240v input...
Post #607290 25th Sep 2021 12:33pm
Likeomg
This makes a lot of sense - i bought a L405 2 months ago now and haven't seen it.. Still bobbing around offshore.
Post #607291 25th Sep 2021 12:34pm
Likeomg
Now i know the battery is in the back, very easy install, it will just be a temp thing so it will be case of running two cables and leaving it loose in the back.
Post #607292 25th Sep 2021 12:40pm
thats the auxiliary battery that is shown in Alistairs pic...you may have one or you may have a capacitor..
your main battery is under the spare wheel. ... - .- -.
Post #607293 25th Sep 2021 12:45pm
As Stan says, the main battery is under the compressor, under the spare wheel - I've got an Andersen connecter permanently wired to mine in case I need to connect it to anything.
There are also hard wired charging posts under the bonnet and I've done the same thing there
So if you don't mind a more temporary, plug in solution, then either of those may be an option.
Post #607297 25th Sep 2021 1:27pm
And if your car does NOT have rear AC & heating then the LHS cubby will be empty Thumbs Up Thumbs Up
Post #607304 25th Sep 2021 3:57pm
Likeomg
I believe it has rear AC & heating, its a 2015 AB but again - i sent my farther to test drive & buy it as im overseas.
From the pics i have anyway... Embarassed
Post #607313 25th Sep 2021 7:58pm
