Home > Technical (L322) > 4.4 TDV8 total electrical failure
Spike
United Kingdom 2004 Range Rover Vogue Td6 Monte Carlo Blue
Good morning all, I have had a call from a friend to pick him up stranded, he was driving back last night when his lights briefly flickered then an instant and total shutdown, luckily he managed to steer in to a gateway, nothing left at all not even hazard lights, it can't be winched as it is of course in drive, has anyone come across this before? Many thanks
Post #607345 26th Sep 2021 9:08am
Sounds like the alternator has packed up.
You should be able to winch it but you have to put it in Neutral. There is a release under the centre cupholders, details in the manual, not sure if it releases it from D though as it is usually used to release it from P. There is nothing that can't be fixed with a hammer😜😜
Post #607349 26th Sep 2021 9:19am
Spike
Thank you, would alternator fail drain the battery instantly? The AA on on the way!!
Post #607357 26th Sep 2021 9:50am
GraemeS
Australia
A flat battery will occur within a very short time if a diode fails short circuit.
Post #607361 26th Sep 2021 9:59am
JayGee
Do alternators on this engine show any warning signs before they fail ( weeks / days and not seconds) or have an average mileage fail distance? 2012 TDV8 Vogue (L322)
Post #607372 26th Sep 2021 11:04am
Spike
Thanks for your help on this, AA man thinks it's a short at the back of the alternator, apparently access is restricted from above so he can't tell exactly, on a recovery truck now, it drained his power pack instantly then when ho hooked her up with jump leads there a smell of burning so switched straight off, I will let you know the outcome. Cheers
Post #607373 26th Sep 2021 11:15am
DrRob
I reckon alternator has gone and taken battery with it. Always put a new battery on when a new alternator is fitted. 019 AGM on a 2011 4.4 Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #607374 26th Sep 2021 11:19am
GraemeS
Australia
The power diodes used in the brand of alternators that LR use are avalanche (Zener) diodes used to prevent excessive over voltage, a condition that can occur if for example the battery becomes disconnected while the engine is running. These diodes have the characteristic that once their trigger voltage is reached they reverse conduct, thereby causing an instant reduction in voltage. The problem is that as the diodes age, which is accelerated when they've been working close to their current capacity, is that the trigger voltage lowers eventually getting down to battery voltage at which point one or more reverse conduct causing an almost dead short. Because LR attach the alternator's output cable to the starter cable, the much higher current capacity of the fuse on the starter cable won't blow when the alternator diodes short circuit back through the windings.
Some other alternator manufacturers use normal diodes for power diodes and use avalanche diodes in the regulator circuit to handle over-voltage without causing a short circuit of the battery. I fitted a separate power cable with an appropriately rated resettable circuit breaker to the alternator of my previous D4 but haven't yet fitted one to the L322.
Post #607394 26th Sep 2021 12:27pm
Spike
Just to update, he picked her up yesterday and indeed ''twas the alternator" they checked and said battery was fine so didn't change it, £600 bill apparently they are very awkward to do, thanks for your input.
Post #607830 1st Oct 2021 8:29am
They are awkward to replaced but a £600 bill is actually pretty reasonable Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #607844 1st Oct 2021 11:15am
JayGee
Parts are cheap on these engines (it's a Ford!) - it's the labour involved in fitting them that's expensive! I'm sure the garages actually prefer working on D3/4/RRS where you can just lift off the body to get at everything?
I'm going to need some work done on the aux belt system and it may be just cheaper to get the alternator replaced while they are at it. 2012 TDV8 Vogue (L322)
Post #607845 1st Oct 2021 11:22am
