![]() | Home > Maintenance & Mods (L322) > FBH issues |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1053 ![]() ![]() |
You have selected the wrong heater type from the drop down list try going back over your settings |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
Ah ok, I had selected Thermo Top C/Z BMW as that was suggested on most of the forums I had seen.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Do you have IID? |
No, I just have the Webasto diagnostic software. |
Follow this guide
This evening I had a friend clear all the codes in the car, I didn’t see what the one for the fbh was unfortunately, anyway tonight I switched on the manual heat via the touch screen and the FBH fired into life, the pump was clicking and I could smell the fumes although I didn’t see smoke. The fuel pumped stopped after a couple of mins and the the FBH switched of shortly after.
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
Unless your 12v battery is absolutely top notch the FBH wont run for long. Mine was exactly like this, i proved it by running the FBH with a battery charger connected, it then ran on as it should, I fitted a new 12v battery and was greeted every morning with a nice warm car. BMW i3 Electric Car
Sorry all, didn’t realise that I hadn’t posted an update for this, the problem in the end was the fuel dosing pump, even though it was clicking it wasn’t actually pumping any fuel to the heater.
