Home > Maintenance & Mods (L322) > Oil change 4.4 TDV8 2011
Timo
Netherlands 2011 Range Rover Autobiography Black 4.4 V8 Barolo Black
hey. im sure this has been talked about often but i couldnt find what i was looking for. i want to change my oil before i go to spain. there is a hose going into the side of the pan. a blue one. can i just disconect this one for it to drain the oil?
Post #608366 5th Oct 2021 6:37pm
rjff
The how to is in the workshop manual to make sure you have the correct pipe. Follow:
wiki
workshop manual 2011-12
engine
oil changeing
draining
It's much easier however to buy a suction unit and use the specific suctioin tube to the out side of the main oil filler cap. I'll post a link to that unless someone beats me to it.
Over to you I think, Mike (BB) Cheers
Richard
Gap IIDBT
Post #608376 5th Oct 2021 8:04pm
rjff
Something like this but better if you can find a one for 10 litres
https://www.amazon.co.uk/Autojack-Vacuum-E...B08W1H94VF
The better one is a Draper but that's much more expensive. Cheers
Richard
Gap IIDBT
Post #608378 5th Oct 2021 8:10pm
Baltic Blue
This should help….
https://www.fullfatrr.com/forum/topic41966.html
Cheers
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #608391 5th Oct 2021 9:08pm
Baltic Blue
Also, someone posted good reviews of this cheaper solution if you have got a suitable empty container.
https://www.machinemart.co.uk/p/clarke-cht925-manual-siphon-pump/
Post #608396 5th Oct 2021 9:19pm
