![]() | Home > Technical (L322) > 2010 5.0 SC Multiple warning lights. |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
Never looked under the bonnet of an SC, but my 'guess' would be that a belt has failed, hence no power steering and the electrical / other faults because the alternator is no longer charging the battery ?
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701 ![]() ![]() ![]() |
As Merchy said, if the belt's ok then everything points to the alternator.
Connor Member Since: 11 Sep 2021 Location: UK Posts: 3 ![]() ![]() ![]() |
Thanks! Whats the best way to check if it's the belt? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
The diesels eat starters and alternators, not so much the petrols...
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
You should be able to spot if the belts are still intact. You don't need the engine running so if you're not mechanically minded don't have it running when you start poking about.
The belt winds it's way around several pulleys, so if you research this drive belt, it is sometimes called a serpentine belt, once you see it you will realise why, as in above post, for safety reasons, best check / poke around with engine stopped. |
