Home > Maintenance & Mods (L322) > Brembo Calliper Painting
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
I need to change my discs and pads because I keep smelling a burning clutch type smell when getting out of the car.
as my callipers were looking pretty manky, I decided to get them painted before changing over the pads and discs.
You can see they look a bit ropey.
as they are six pot alloy brembos i feel they need to have a bit of love and care. i have already flushed through all the fluid.
the pins should look like this, and the nearside came out fine.
unfortunately the offside pins were stuck fast and ended up bending when i was trying to drift out. i had to cut them in half with a dremel in the end and then drift out the remaining bits.
this is what the pins ended up looking like when they were finally extracted.
a wider angled shot
couple of coats on the calliper - the paint is exceptionally thin and runs really easily. i found a dust coat is the best way and then after about 10 coats i hit them with a thicker coat which then leaves a much shinier finish.
this is the finished product (minus the new decals - in the post)
Post #608855 11th Oct 2021 4:16pm
Caesium
Not sure what's happened here. The images were showing originally and now they're not.
**EDIT** The original post above worked for a few minutes and then stopped working.
Looks like the forum host software adjusts the URL of the image hosting to include a dimension for resizing the image.
It also seemed to change the picture URL from UPPERCASE to lowercase which then broke the image link. I've changed again, not sure how long the images will stay there for.
Perhaps admin need to look at the image resizer as it's adjusting the explicit URL where case sensitivity is a make-or-break issue.
Post #608856 11th Oct 2021 4:35pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Just in case no one believes you, I can confirm that they were there! Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #608857 11th Oct 2021 4:40pm
TDV8 Paul
Looks good! I need to do this, but I can’t decide on a colour yet 2009 (2010 MY) 5.0 Supercharged Autobiography
2007 TDV8 Vogue SE
2005 BMW E63 645ci
2024 Porsche Macan
Post #608887 11th Oct 2021 9:33pm
Caesium
An update after decal application.
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #609118 14th Oct 2021 1:50pm
Looks like a good job there Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #609133 14th Oct 2021 3:52pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Nice job!
Some q's if I may please.
How many cans of paint used for 2 calipers?
How many coast applied? - I suspect 3 but you mentioned 10, but I think that was probably the waiting time!
What preparation was involved?
Thanks in anticipation. I have a set needing to be done, but need to explore wheel nut removals first!
Chris
Post #609164 14th Oct 2021 5:52pm
DrRob
Did you scrape the old Range Rover lettering off with a blade? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #609166 14th Oct 2021 5:58pm
Caesium
Used a wire brush and 320 grit paper to clean them up, plenty of brake cleaner to degrease and clean then loads of masking.
Another spray of brake cleaner and then hit it with the spray.
It’s really thin paint and a heavy coat just runs so I sprayed it with about 10 coats over the whole day with 20-40 mins between coats.
Last coat was as heavy as I dared to bring out the shine as light coats leave a satin/matt finish.
I’ve used a cam and a half to do the two front callipers. Still got the back ones to do. Christian.
Current Cars
2019 BMW X4
or
Post #609167 14th Oct 2021 6:00pm
Caesium
Here they are all back together and the view through the wheel (they're next to be refurbed)
 Christian.
Current Cars
2019 BMW X4
or
Post #609347 16th Oct 2021 9:21am
marsie
England 2014 Range Rover Vogue SE SDV8 Loire Blue
Nice job, look loads better. I did mine recently but went for silver with red decals but now I have swapped my wheels I am wishing I had gone for something a bit brighter Paul
2014 Range Rover vogue se 4.4sdv8 Loire Blue
1992 Range Rover Vogue LSE 4.2 Ardennes green
Post #609509 17th Oct 2021 5:47pm
G3BML
Scotland 2010 Range Rover Vogue SE TDV8 Santorini Black
One of the jobs on my to-do-list Very Happy the big callipers looks great in red
Post #609642 18th Oct 2021 8:19pm
nearlee
Wales
I hand painted mine, 3 coats on the yellow
 Remember:- amateurs built the ark
Proffesionals built the titanic
Post #609651 18th Oct 2021 9:05pm
strongstuff
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
Handpainted here too, used Halfords engine enamel and a brush.
 2008 L322 4.2 V8 SC Stornoway Grey
2006 L322 4.2 V8 SC Java Black
Post #610019 21st Oct 2021 7:55pm
